Anyone used Kincrome gear clamp set for timing belt?
This https://www.kincrome.com.au/product/K81 ... lamp-4-pce and / or know if it will work on our engine?
I've got to take the belt off again and it was a bitch last time trying to clamp the cam gears in place.
Re: Anyone used Kincrome gear clamp set for timing belt?
Can't say I have. That said, Kincrome make a reasonable bit of kit. My socket set is mostly Kincrome.
What do you use to clamp the cam gears Ben?Bennoz wrote:Can't say I have. That said, Kincrome make a reasonable bit of kit. My socket set is mostly Kincrome.
EDIT:Bought for 55 dolla, will let you know if they work or not.
Yeah I use a Kincrome socket set at work too among other stuff.
I (we/martin) used Fraz's Kincrome cam lock tools on both my car and Long's car. They were a bit flimsy and slightly dodgy, but they got the job done. Not the same ones as those ones, though, they were these ones:
Ah yeah I saw those ones, would have needed two sets though.
I just let them spring back then reset the timing. :lol:
I made something up, couple plates & a bolt lol
I don't use clamps
Fingers?
Wedge something else in there?
- payaya
1/3 turn counterclockwise on crank pulley stops the cams from springing. It tells ya in the manual.
Or do what mechanics do, vice grips holding both pulleys just a bit of tension will hold them in place.
