'metal to metal' sound over bumps?
hi, before i get it checked by the suspension guy, do you guys know what this could be? is it an easy fix? i get this problem occassionally...
its coming from the front driver's side only....
any help appreciated, cheers...
whats nolathane? you can get polyurethane ones from whiteline or kmac or pretty much any suspension place.... as for rubber ones, northshore mitsuJono wrote:
Im trying to source a Nolathane bush for the stock sway bar but im finding it hard.,..
Jono
the noise could also be the drop links...
cheers
simon
yeah you have to get the right size bushes otherwise your swaybars wont get proper support... try giving whiteline a call... im sure they have 16mm bushes that will fit our cars...even if it was made for another car, im sure they could find something to fit properly...Jono wrote:i think nolathane may be same kinda thing as poly@$@%
ive looked up on Whiteline, but they dont have the 16mm standard swaybar bush, i think they only have 17mm..
does the size matter?
Jono
it could be a few things.... it could even be the bottom of your suspension strut hitting your spring... but more than likely its the bushes or the droplink.... take your wheel off and try and move the droplink....if it has any play in it, then its the drop link... or try and move your swaybar and if you hear it clunking around, then its the swaybar bush...Adriano wrote:hmmm, so im guessing its the bushes then??
i know nolathane is a brand name... so its like whiteline polyurethane bushes just diff brand i guess? its red in color as suppose to whiteline's yellow ..
simon
