light issue
adzski
light issue
Post by adzski »
last night when i got home, i couldn't get my parkers to turn off + dash lights.
flicked the headlights on multiple times to see if it would work, and fog lights, but it didn't work.
tried disconnecting the battery, but it didn't work.
anyone had the issue before? is it a stalk issue?
Re: light issue
:lol: so they stayed on without power?
Perhaps you had too much acid before u came home & those mushys you stopped and picked weren't "normal" mushrooms
Re: light issue
Yep, cant stay on with battery disconnected. Could be the switch I guess.
    adzski
    Re: light issue
    Post by adzski »
    hahahahaha toby
    anyway i didn't mean when i disconnected the battery they stayed on, i mean once i re connected the battery the turned back on. everything is switched off on the stalk, but the parkers are still on.
    Re: light issue
    Vectose is usually pretty good with this sh*t.. Are they LEDs & have u installed anything extra lately? Like a stereo or extra lights n sh*t
    pull the relay to isolate the problem... ie if you pull the relay and the lights stay on then its not the switch/relay, but more like a short on the park/dash/tail light wiring.
    adzski
    Re: light issue
    Post by adzski »
    pulled they relay, lights were still on. think i will just take it to an auto electrician
