need help
kds1
need help
Post by kds1 »
Hi guys I have a hopefully small issue I have just done a service oil filter oil and air filter went for a 20 min run pulled in the driveway let it sit idle and a few revs checking for smoke and the radiator fan switched on temp gauge only sitng on halway normal .engine sounded like I lost a belt or something . So I looked under the car and smoke coming of the exhaust at the back of the motor but can't see oil leak any ideas. Started fine 10 minutes later but noisy tic.
Nulon 10w 40 hi performance oil
Ryco z411he filter
Standed air filter
Moused
Re: need help
Post by Moused »
What model do you have?
The ticking is likely tappet noise - which can be made more apparent after an oil change..
It's not terminal, and nothing to worry about if it's the case.
Did you recheck the oil level after your drive?
As for the smoke, it could be oil burning off the bottom of the sump / near oil filter from draining it (or if you spilled any refilling?).
Radiator fans at idle is normal.
Re: need help
20 minute drive then idling with rev checks would turn on the radiator fans.
kds1
Re: need help
Post by kds1 »
All good guys just give the engine a good clean up and yes I spilled some oil when filling. Thanks for the advice I'm new to cars normally work on bikes first car in 5 years so I will probably be asking some stupid questions but have to start somewhere
Cheers
Scorpionwally8
Re: need help
Post by Scorpionwally8 »
How did you clean the engine bay , what with?
Re: need help
Scorpionwally8 wrote:How did you clean the engine bay , what with?
Apparently oil
kds1
Re: need help
Post by kds1 »
Yep oil . It was pretty clean when I got it
Scorpionwally8
Re: need help
Did he tell you that he had trouble parking it when you brought it off him lol
kds1
Re: need help
Post by kds1 »
Lol he didn't look comfortable driving it
