Hi guys as you no I'm a bit of a noob with the fto. I been having problems with the mivec not kicking and rev cut off 6100k ran the diagnostic trick and have 64 error alternator . I have checked all connections and noticed the alternator belt was new and repco brand so I thought might give them a call to verify it's the right one turns out its not. No my question is the belt that's on it is shorter the belt that's supposed to be on it will this stop the mivec from kicking
Belt that's on my fto 4pk940rb
Belt that should be on it 4pk950rb
wrong alternator belt
- kds1
- kiz
- SA Coordinator
Re: wrong alternator belt
Are you sure you can't get it on. Have you loosened the tensioner and then retensioned?
1998 Mitsubishi FTO GPVR AERO
- kiz
- SA Coordinator
Oh, you got it on, No this will not affect it.
Check alternator plug
Also make sure you've got all 4 pins on the plug there, I recently found out I'd burnt out 1 pin and so mivec was sparatic
- kds1
Thanks mate she's a reco job on the alternator I think cheers
Yep, but sometimes, instead of putting in the proper alternator (4 pin plug), people put in a GR alternator (2 pin plug) and if this has been done, you wont get mivec until you swap the alternator for the proper 4 pin one.
- kds1
It is the right one 4pin and the auto electrician has worked on them and knows the problem he asked me the same question I think ill be in good hands
