Many years ago, I mentioned PFR6G-11
The actual part number is not mentioned in my last change, 5 years ago, as my mechanic bought it from RPW and I cannot find any mention of the actual part number.
Searching around in the forums seem to indicate that for normal driving, PFR6G-11 should be fine.
Most posts seem to say PFR7G-11 though, or the equivalent Iridiums, BKR7EIX-11
Can someone confirm? Just trying to acquire the parts needed for my next 100k servicing.
Camskill parts division's closure last month certainly did not help.
Spark plugs for auto 95 GPX
- yotka
Re: Spark plugs for auto 95 GPX
7 are the correct ones for the MIVEC engine.
6 are the ones for the non-MIVEC
- yotka
Ok!! Thank you.Vectose wrote:7 are the correct ones for the MIVEC engine.
It looks like the iridiums are $90 off ebay at the moment.
http://www.ebay.com.au/itm/NGK-Iridium- ... 1605310764
- kiz
- SA Coordinator
Yea heat rating 7 as said above.
Another option is BKR7E11 which are the non iridiums and pretty common if they don't have BKR7EIX-11
1998 Mitsubishi FTO GPVR AERO
Yeah BKR7EIX-11
Just get the iridiums, who could be bothered pulling the manifold again
- yotka
Hello again.
I was just about to get the above mentioned Iridiums(IX), but noticed they are only rated for 60k kms.
The platinums I had were rated for 60k miles.
Looked up NGK's website, and the Iridium Laser are rated for 100k kms.
I have no idea what the part number for the laser range is.
Can anyone help?
Can anyone help?
- yotka
OK, did some more searching, and I think I will get the PFR7M instead, for a 100k kms service life.
