WTB: Driver side window regulator
Private Sales Only
DODO``
Post by DODO`` »
While my GPX was with the previous owner, someone pushed the drivers side window down (possibly in an attempt to steal it). In result, the window wont stop when it reaches the head of the frame, instead it thinks the head of the window is an obstacle and comes back down few centimetres. ( I think its a safety feature? )
Is there a way to fix this without changing the whole regulator?
if yes can anyone shad a light on how?
it no, I need a regulator :) let me know if anyone has a spare one.
I should check with dstocks too..
Re: WTB: Driver side window regulator
That's not a regulator problem. It's an alignment problem.
All the regulator does is move the window. If it does that then it's fine.
DODO``
Post by DODO`` »
Vectose wrote:That's not a regulator problem. It's an alignment problem.
how do I fix it, sir Vectose?
You adjust the bolts on under the door lining...
    DODO``
    Post by DODO`` »
    Cool! Thanks ill give it a go!
