Page 1 of 1
PCV breather hose, rocker cover to rocker cover replacement
Posted: Mon Aug 01, 2016 9:43 pm
by yotka
Hello,
Does anyone know the part number for this, rocker cover to rocker cover breather hose?
(Might have found it, but need someone knowledgeable to confirm.)
Pictured with red arrow attached.
Cheers
edit: added cut off diagram with red arrows(MD320259 HOSE,ROCKER COVER BREATHER CROSS-OVER).
Re: PCV breather hose, rocker cover to rocker cover replacem
Posted: Tue Aug 02, 2016 3:13 pm
by yotka
Updated with picture and rocker cover to rocker cover description.
Posted: Tue Aug 02, 2016 8:38 pm
by yotka
Cut off diagram with arrows attached.
Posted: Wed Aug 03, 2016 11:23 am
by Rob Furniss
Well done mate yes you've found it. Tried firing up my ASA yesterday to have a look for you but its seems to have stopped working since I upgraded to Win10.
I would have thought you could replace it with something generic if you're struggling to get one or if expensive.
Posted: Wed Aug 03, 2016 2:29 pm
by yotka
Hi Rob!!
Thank you!
Appreciate the help and am glad someone is trying to assist.
I noticed the number of read counts was pretty high, so I figured there is some possible help coming but there is probably something in the way.
It is better to post correct information that had been cross checked.
As for the other question/comment,
A generic part could be made up, but the bigger the part, the harder it is, and this is slightly curved and thick.
I won't be the one doing the work, so it is best to get the appropriate part where possible.
My mechanic friend had been very patient with me, and its the least I can do for the 3 major jobs upcoming, of which one is a radiator + cooling/transmission/heating hoses replacement.
Posted: Wed Aug 03, 2016 7:36 pm
by silverGPX
Just order it from amayama, use complete FTO for the part numbers...?
Posted: Wed Aug 03, 2016 7:52 pm
by yotka
Yes, Amayama most likely.
edit: for this hose, I was unable to access any diagram on completeFTO, and had to use 3rd party sites.
Posted: Wed Aug 03, 2016 8:12 pm
by Vectose
Posted: Thu Aug 04, 2016 12:11 am
by yotka
I know, but being an armchair mechanic, without that exploded diagram, the words there are not very useful, especially the term I was given is rocker cover to rocker cover breather tube.
Changing it to cross breather might be self explanatory, but, you can't be 100% sure.
Posted: Thu Mar 09, 2017 12:25 pm
by yotka
Not made by Mitsu anymore.
Neither Viamoto, nor Amayama were able to get it for me.
Posted: Thu Mar 09, 2017 8:44 pm
by silverGPX
Just get some pipe from autobarn
Posted: Fri Mar 10, 2017 11:33 am
by Bennoz
This ^^^
What is it, 10mm or something?
I just replaced most of my factory rubber with the aeroflow stuff. Got it off ebay.
