Fto brake upgrade
Spike28278
Fto brake upgrade
Post by Spike28278 »
Im looking to upgrade the frint and rear brakes on my fto, im looking for some advice if there are any kits available for front and rear, and weather i shoyld go 6 pot or 4 pot
Re: Fto brake upgrade
Go 12 pot bro it's needed for when mivec kicks in
Sahin wrote:Go 12 pot bro it's needed for when mivec kicks in
Bruh, 14 pot is where it's at.
Spike28278 wrote:Im looking to upgrade the frint and rear brakes on my fto, im looking for some advice if there are any kits available for front and rear, and weather i shoyld go 6 pot or 4 pot
4 piston is more than adequate.
There are kits from PB brakes, and JustJap offers ATTKD ones. Other options are GTO brakes, Evo Brembos (whether with a adapter bracket or hubs and arms). Freaky Parts in the UK also offer Wilwood and another kit.
Does that say 'YOLO' on that caliper? Fitting if it did...
Bennoz wrote:Does that say 'YOLO' on that caliper? Fitting if it did...
I'm just waiting for calipers that cover the entire rotor. :lol:
Just use brembo covers for the rest of it
But what if someone wants to be able to stamp on their brake pedal, and shatter the pads, rotor, hubs and driveshafts all at the same time??
evo-gsr
Post by evo-gsr »
Can the later models evo knuckles be bolted on to the FTO? Then Brembos would be a bolt on affair??
evo-gsr wrote:Can the later models evo knuckles be bolted on to the FTO? Then Brembos would be a bolt on affair??
That's what Bennoz did, and I followed suit. He's using Evo 3 arms with a different balljoint to suit the Evo 5 hubs, but I went all Evo 5 (since the arms were available). Was expensive to refresh all the parts though.
mongoose_dog
Post by mongoose_dog »
Another solution is to use the caliper bracket MR307282 from Outlander, Airtrek and Magnum. This one lets you keep the twin pot front calipers with the same pads, and put a bigger brake disc - from 276mm to 294mm one, again from the Outlander, or the Evo 4.
Spike28278
So I ended up finding a bloke selling a gto brake conversion kit (discs, calipers, lines, pads abd brackets) and paid about $350 for the lot, gonna install them hopefully in the next few weeks
Sent from my SM-G930F using Tapatalk
Taiwo
Post by Taiwo »
Spike28278 wrote:So I ended up finding a bloke selling a gto brake conversion kit (discs, calipers, lines, pads abd brackets) and paid about $350 for the lot, gonna install them hopefully in the next few weeks
THat is super cheap well done man. Well done.
"Is that a supra???".
"What's a Mitsubishi FTO?"
Spike28278
Yeah I was stoked!
But my wheels dont have enough offset... so ill have to figure something out haha
evo-gsr
Post by evo-gsr »
Should get these...
Where's Rob? We saw these rotors the other night :lol:
