Page 1 of 1
6A12 weight?
Posted: Fri Oct 28, 2016 7:00 pm
by Rob Furniss
I did a search and not found anything definite, one thread saying it should weigh 180 - 200kg, anyone know the actual?
Need it for freight quotes.
Cheers,
Rob
Re: 6A12 weight?
Posted: Sun Oct 30, 2016 2:35 pm
by Sahin
It doesn't weigh that holy sh*t
I've deadlifted one of these up on my own I reckon it weighs 100-120 max
Re: 6A12 weight?
Posted: Mon Oct 31, 2016 10:25 am
by Rob Furniss
Sahin wrote:It doesn't weigh that holy sh*t
Well you are the Hulk, maybe you're underestimating.
Re: 6A12 weight?
Posted: Mon Oct 31, 2016 1:09 pm
by spetz
It definitely weighs more than 100-120kg.
All alloys I4 engines weigh more than that.
I believe the 4G92 MIVEC was around 150kg or so (not confirmed) so the V6 would be a fair bit more.
Re: 6A12 weight?
Posted: Mon Oct 31, 2016 7:35 pm
by kiz
All I know is they're f**king heavy. But yea would be up at the 100kg+ range
Re: 6A12 weight?
Posted: Wed Nov 09, 2016 2:25 pm
by Rob Furniss
I sent Mitsubishi Motors Australia an enquiry and they sent it across to Japan (apparently) but have now drawn a blank:
Please be advised that unfortunately we are no longer able to provide weight information as Mitsubishi Motors Corporation no longer stock these items and replacement engine weights were not recorded.
MMAL trust the above is of assistance.
Thank you for your enquiry.
Go with 180KG for the freight?
Re: 6A12 weight?
Posted: Wed Nov 09, 2016 3:24 pm
by Sahin
Just under declare it and then they weigh it and charge you the difference that's what I did all the time
Re: 6A12 weight?
Posted: Wed Nov 09, 2016 4:52 pm
by Rob Furniss
Sahin wrote:Just under declare it and then they weigh it and charge you the difference that's what I did all the time
Ok good idea, better than over declaring I suppose.
