Need some gearbox advice
Mivec swapped gx
Post by Mivec swapped gx »
Does anybody know for sure if there are any stronger manual gearboxes that bolt upto the mivec engine as mines on its way out and im wanting a box that can handle more power,
Thanks in advance
Re: Need some gearbox advice
None
Mivec swapped gx
None at all? Anyone know roughly how much it would cost to uprate the fto box for around 300hp
Stock box will handle that fine.
Only issues are input shaft bearings. Same as the EVO boxes.
Mivec swapped gx
Any chance you know the best input shafts/bearings to get for it then, just dont want to go get a new one then something goes wrong
Thanks for the quick response
Stock
Just don't launch it 24/7 she'll be rite
Mivec swapped gx
Lol thanks man wasnt to sure
The real question is what you're gonna be doing to take it to 300hp anyway :lol:
Exhaust and pod filter
Taz is back \o/
Sahin wrote: Fri Jan 12, 2018 10:35 pmTaz is back \o/
Vectose wrote: Fri Jan 12, 2018 10:23 pm Exhaust and pod filter
Make that two pod filters
twin pod lol.jpg (110.31 KiB) Viewed 3385 times
I see a cool air intake. Its got a Nos fogger system and a T4 turbo. I see an AIC controller. It has direct-port nitrous injection and a stand alone fuel management system. Not a bad way to spend 10,000 dollars.
It's lasted 20 years on the factory bearing, just replace it. By the time it goes again you'll be in a camry.
Bennoz wrote: Sat Jan 13, 2018 12:02 pm It's lasted 20 years on the factory bearing, just replace it. By the time it goes again you'll be in a camry.
Unless he drives it like you
bjk wrote: Sat Jan 13, 2018 12:29 pm
And look where I ended up. In a Commodore :lol:
Bennoz wrote: Mon Jan 15, 2018 11:21 am
Shame. Shaaaame!
And I ended up in a camry (sort of)
He’s selling parts on gumtree now.
http://www.gumtree.com.au/s-ad/wynnum-w ... ios_social
evo-gsr
Post by evo-gsr »
Please.. .give the back story on Taz?
Pm if need be.
