cheap 17's?
cheap 17's?
i am currently looking for a set of 17x7 or 17x7.5's (stock wheels are tooo damn narrow!) but i cant really justafy going over the price of a set of tires to my budget :/
anyone know of anyone selling decent 17's second hand or otherwise for around 1k with tyres?
- Boris
Well, for that price.... no....
You could try, http://www.tempetyres.com.au/
As a number of people of this forum have bought from there and they say it's pretty good...
Good Luck...
Good Luck...
Re: cheap 17's?
I assume you are buying purely for looks then.paladin wrote:stock wheels are tooo damn narrow!
MIVEC is My Friend :D
Most places are not familiar with the settings for indvidual cars so they set them as close to zero as possible.
However, you want your car setup for how you drive.
If the rear is sliding out, I'd start by making sure there was a negative camber on the rear wheels (probably around 2 degrees).
The FTO is a very good handling car and to have the oversteer you speak of is quite unusual, so I suspect the previous suspension place put the camber on the rear back to 0, which would actually create some instability in the FTO, as it has a negative camber as standard.
Make sure you get a print out when done, this will show you all the various settings such as camber and caster etc.
Hey if you still want to get some bigger wheels..
www.upimports.com.au
www.option1garage.com.au
They have some good ones i think.
Jono
Jono
Jono
