clicking sound
ANBU_fto
clicking sound
Post by ANBU_fto »
hey guys... i swear!!! this fto is giving me so much trouble!!!
well anyways...
today i dropped off my car at the workshops to get it checked about the shaking problem.... ok.. the guy said bring it back in two weeks and i shall look at it for you... so i was like ok... as soon as i turned my key... the car didnt start.... it gave out this clicking sound....
guys could it be the starter motor?
...groOl...
08 Evolution X - White
97 Gpx Fto - Racing Red
mxysxy
Post by mxysxy »
I am a newbie, so, wondering how much you should take my recommendation seriously, however, your problem sounds to me like there is something wrong with the battery.
Might be out of charge, which might mean that a new battary required or alternator is not working properly or the alternator belt perhaps.
How about trying to turn on your low beams and try to turn the engine on. If low beam lights are reducing that this is definitaly something with your battery.
Boris
Post by Boris »
Ok, I'm 85% sure it's your starter motor. Firstly, if the battery was flat, ANBU_fto would of mentioned it, the clicking is the the sound of of the starter motor... cos i had that happend to me, lucky i have a manual, btw the clicking shoulf be coming from your passanger side... :|
Well, all I have to say, is, do a search for other starter motor threads, which might help you out to temporarily fix the problem, but the worst case scenario your looking at reconditioning you starter motor. that's if i'm correct.
onnzo
Post by onnzo »
If it is your starter motor, take a metal pole and give it a little whack. If it starts after a whack, its time to recondition or replace the starter motor.
Mike
ANBU_fto
Post by ANBU_fto »
guys how much would it cost for a new one, and to reco one?
...groOl...
Jono
Post by Jono »
The click noise is should be coming from both drivers and passenger side as the starter motor is located at the centre front of your engine bay
just a bit of correction.. :)
Jono
RedlineGX
Post by RedlineGX »
Had the same problem a while ago.... a whack on my starter motor worked....better yet if you whack it while someone else tries to start it...soon after I changed the battery and the problem went away...
smorison
The Godfather
Post by smorison »
before worrying about starter motors... check your battery!
When you turn you can on (without starting it) is the battery level low???
(if yes could be battery)
Does it charge when the car is running?
(if no then alternator)
Batteries are cheap
Alternator reco units we can supply on an exchange basis pretty cheap.
Starter motors haven't had to worry about yet but i'm sure i could source one from an aussie car.
HiRAEdd
Post by HiRAEdd »
ANBU_fto wrote:guys how much would it cost for a new one, and to reco one?
The FTO I just bought has reconditioning the starter motor or something like that in it's service history last year. They charged $640 for it.
ANBU_fto
Post by ANBU_fto »
omg!!! 8O 8O 8O 8O 8O 8O
thats like heaps....
im heaps dead now... crap....
but anyways, my car has started.... lol it was the battery, some num nut hit one of the cable things on the battery to hard and cracked the battery itself, it was leaking acid...
...groOl...
smorison
The Godfather
Post by smorison »
ANBU_fto wrote:omg!!! 8O 8O 8O 8O 8O 8O
moral of the story??? start with the small things and work your way up
HiRAEdd
Post by HiRAEdd »
All's well that ends well :)
