6a13 2.5 with 2.0mivec heads timing belt??
CraigMirageV6
Post by CraigMirageV6 »
Hi all,
I recently put 2.0v6 mivec heads onto a n/a 2.5v6 block. But I can’t get a timing belt to fit it. Has anyone done this before and if so what timing belt is used? the 2.5 belt doesn’t work it’s too short. I know I can raise the bracket up that holds the top tensioner so my 2.0 belt could work maybe but looking for a belt to fit right onto it. :D
Thanks
getonit
Re: 6a13 2.5 with 2.0mivec heads timing belt??
Post by getonit »
Pretty sure you did not need to start a new thread, But then, you are a Mirage owner,
If you know that you can raise the bracket, why not just raise the bracket?
Would've thought the intake manifold would've posed more complications given that's where the guy on ozvr4 ran into more complications.
evo-gsr
Post by evo-gsr »
So many helpful answers......🤦‍♂️
evo-gsr wrote: Mon Feb 15, 2021 2:36 pm So many helpful answers......🤦‍♂️
I mean, he already has the answer :lol:
evo-gsr
Post by evo-gsr »
Clearly....
