To those of you handy with wire cutters & soldering irons, has anyone figured out how to disable that annoying noise the car makes when the keys are in the ignition & the door is open??
Yeah on the Tip there’s a continues beep when you put it on reverse, is a safety device, but my friends thought it was a parking sensor, how embarrassing.
Edit - it looks like you beat me to it! I'm on dial up speeds
That is the link to get rid of the reverse beep. The ignition reminder beep is on the same circuit board. To disable it you have to remove a different diode or resistor if I remember correctly.
Ok, bit more homework into this & those 3 diodes do 3 different things:
1 is key in ignition bleep, 1 is reverse bleep in Tip & the other is headlights left on bleep... gonna take my soldering iron & try until I find.
Heheeeee, beer first mate!!
Im too bad with the old soldering iron - good for lighting the cigs with as well! Got one of them wizz bang ones with the interchangable size tips - just make sure I got the little one on for this
