Hey all time to do the rear spark lpugs on my car!
I went to repco they wanted 29 bucks for the NGK ones! i swear i can get them cheaper but where?
Also i heard to remove the rear plugs ill require some special tool?? I have a spark plug remover sutiable for the front plugs can i use it at the rear banks?
if not anyone know where i can get one of these special tools?
Its a normal spark plug tool to get the rear ones out. I've changed mine and it took 1 hour because i had to take the manifold off. So yeah its a pretty easy ask if your patient and have the time
on the weekend i got some prices for NGK platinums (PFR6G-11) and iridiums (BKR6EIX-11) from sprint auto parts. prices for both types were $17.95ea. these plugs are for the gr though.
I'm also interested to find out where to get them from in Melbourne. Gonna do a major service soonish and replace the rear spark plugs.
How often do the front and rear plugs have to be changed and which ones would you use for the rear in order for them to last longer (since they are much harder to get to)?
Papaya, try Auto Parts on Barkly street in Footscray. I just found out that place myself. You can also get a headlight bulb for only $13 there. Last time I got it from SBE888 for 50 buck each. You may try Auto Parts in your area
I have the denso irridiums from uas, they are grea,t (except you have to repalce them every 30,000kms) i got them for $22 each, and are the same as (or nearly the same as) the hks ones
