hey guys jsut wondering
can i connect my psp to car speakers through the headphone plug?
like i buy a conversion wire from headphone plug that splits into red and white cable???
i dont know much about these hings can anyone help?
mounting psp in the single din is no problem
connecting PSP to car speakers?
- fto617
- FTO338
There should be two or four screw at the font holding the unit against the mounting bracket, depends on your setup, unscrew them & you should able to pull your head unit out. Please note, if the unit is screwed from the side of the bracket, you just have to take the unit & the bracket out at the same time.
If it doesn't have screws at the front so you can just slide your unit out.
