Clutch replacement
- GPXXX
Clutch replacement
I'm curious to know what sort of clutch some of you guys are running on your car atm...
I'm driving mine on borrowed time at the moment so I need a clutch replacement REAL SOON.
Any recommendations as to what brand to go for / how much to pay / where to get it done in Melbourne??
Thanks for your help!
- Mitsiman
RPW sells a lot of the Semi Ceramic paddle clutch disc packages which are great.
Retains all the driveability of standard but 50% stronger and will take a beating without failure.
They are valued at $450.00 on average and last just as long as an origonal under normal driving but take more of a beating. They are not heavier on the pedal so no extra effort involved.
- Mitsiman
WE certainly have along with some brakes, tensioners, heater hoses amongst other things.
But to do a clutch yes you need to remove the gearbox . Normally takes around 3 hours to replace plus the gearbox oil and teh clutch. Average price including clutch etc is around $650 - $700.00 with our Semi ceramic paddle clutch disc
- Chrisp
- elmo
clutch
the semi ceramic clutch is a little bit harder on the pedal but it is definately grippier (is that a word??) It takes a couple of days to get used to but would definately be worth it if you drive hard, and pop the clutch a fair bit ...
- GPXXX
i've got a set of Exedy heavy duty metal clutch kit on order waiting for installation later this week ($900 fitted).
apparently they have a 35% greater clamping force than the Ralliart upgrade (although i never heard of a Ralliart clutch upgrade for the FTO) but it still retains the std driveability and feel.
Will let y'all know how it goes when it's done.
