the UAS ones will be stronger and lighter than whitelines. Also they have master cylinder support included in them allowing for better brake response and feel. I haven't seen Whitelines yet so i don't know what they are like.
on the rear's i only have fixed ones at the moment, we haven't started looking at them just yet however it won't be long before we do. It won't be hard to develop an adjustable one if there is enough demand for it.
The big thing is that as we have front wheel drive cars the back just follows you around. You don't really need adjustable ones on the back, unless your actually racing it on a track.
Sway bars and stuff
- smorison
- The Godfather
The brace was quite expensive. Close to the $400 mark. But it's something you can't get here.wildfaye wrote:how much do u get those creative front under H brace for?
I am in Perth.
I agree with the part on Jap brands, hence trying to find if any Jap makers do those sway bars...hmm..seems like none...
If Stephen comes up with the goods for titanium strut bars for $250, that would be a very good deal. You can't get a titanium bar for the FTO from Cusco. They only make aluminium or steel bars for the FTO.
A Cusco aluminum (Type OS) Cusco strut bar (front or rear) costs about $250 (minus shipping) brand new.
front strut brace question
when fitting front strut braces, should the wheels be on the ground (ie all the car weight on the suspension) or should the strut be fitted with the wheels off the ground (ie say on axle stands). I have checked the dimension in both situations and the dimension is about 6 mm longer with the wheels OFF the ground.
- smorison
- The Godfather
yes it sounds like your bushes.. i have to get mine attended to as well.. front and back for me actually... i'll start a new thread on this..hnm738 wrote:was just wandering that when i hit a bump i get some rattles or bump noise at the back
its not the seat belt something with the suspension would that be my bush wearing out ??????????
thanks
