Looking at that twin turbo mivec motor gave me some ideas and I might try to do a twin turbo setup somewhere in the future as a project...I just wanted to make sure that the turbo manifolds off a 6a12TT from the galant do fit on the mivec motor with out and modifications, and I was also wondering if it would be the same with the 6a13.
I have heard things about with the 6a13 that the rear turbo don't fit in the engine bay of the FTO because they will hit the firewall so thats why they are converted into single, is that true, would there be anything else that the turbo's will get in the way, because looking at the RPW extractors at the front, they are pretty close to the thermo fan.
Turbo Manifold
- bigpitty1
- spetz
Well, considering I saw the engine in real life, I can tell you it all looks standard.
I am pretty sure, the internals from that engine are 6A12TT internals as well, in the MIVEC block with heads.
That engine is for sale by the way.
I think, it's still easier though to just use stock FTO extractors to a larger single turbo.
If you are stuck on twin turbo and it doesn't fit due to the firewall, I am sure custom turbo manifold would solve that problem
- bigpitty1
- RichardB
Re: Turbo Manifold
Thats correct I had to bow the bulk head to get the rear turbo inbigpitty1 wrote:I have heard things about with the 6a13 that the rear turbo don't fit in the engine bay of the FTO because they will hit the firewall so thats why they are converted into single, is that true, would there be anything else that the turbo's will get in the way, because looking at the RPW extractors at the front, they are pretty close to the thermo fan.
