Oxygen Sensor
idawina
Post by idawina »
I had to buy a new Oxy sensor because the idoits in japan cut it off when they did the half cut!
Juat go to any good auto electrical store, ask for a universal 4 wire oxygen sensor. cost around aus $100. they work just fine, been using mine for ages and no probs!
Toohey
Post by Toohey »
Can anyone tell me where the plug is? I've found the sensor but the wires dissappear into the car and then I lose them. Is there an easy way to get at the electrical connector inside the car to disconnect it or do I have to pull apart the carpet and the dash to find it?? :?
bigpitty1
Post by bigpitty1 »
You should still be able to get the connector out underneath the car, the wire goes into a rubber boot, if you pull that out of the way you will see a white plastic clip that holds the boot to the car, take that off and you should be able to get to the connector.
What he said ^
:wink:
Toohey
Post by Toohey »
Ahhh, thats it. :oops: I thought that was just a clip to hold the rubber plud to the car. Thanks Guys!! :D
Nacho
Post by Nacho »
My god it was a b*stard soldering while you're upside down and trying the hold the wires in that crimping thing.
I think the fuel economy has slightly improved but still overall crap compared to what it used to be.
Is the sensor after the CAT the same? We got a part number for that one?
Nacho wrote: Is the sensor after the CAT the same? We got a part number for that one?
Workin' on that one - should have it by tomorrow
bigpitty1
Post by bigpitty1 »
That sensor after the CAT, I'm not sure what it is can someone tell me, I thought it was a secondary O2 sensor but I read some where else that it was a CAT temp sensor and you could remove and put a resistor in its place so the light on the dash won't light up. :?
mxysxy
Post by mxysxy »
waiting desparately to see the DIY
bigpitty1
Post by bigpitty1 »
This is where I read about the sensor after the CAT (meow :lol: )
http://www.ftooc.org/phpbb/viewtopic.php?t=38738
Nacho
Post by Nacho »
I'll write you a quick DIY :wink:
Step 1: Buy new FTO
Step 2: If happens again see step 1
:lol: :lol: :lol:
Wait did you want the DIY for what to do when you accidentally leave the handbrake down when parked near a cliff on the beach?
Just incase anyone elses reads this the secondary sensor mention above was for the cat temp. :D
Storm
Post by Storm »
Nacho wrote:My god it was a b*stard soldering while you're upside down and trying the hold the wires in that crimping thing.
Why didn't you unplug the connector and go and do it on the bench :roll:
AMACHA
Post by AMACHA »
Bennoz how much did mitsu charge to hook your car up to the matrix?
50 bucks :)
Which wire goes to what
Top 4 wires from new O2 sensor: 2 white, 1 black, 1 grey
Bottom 4 from old one: 2 black, 1 white, 1 blue
Bennoz wrote:Image
Thats awesome ben just the way i had it hooked up.
Ps where you been hiding that diagram :lol:
nvr2low
Post by nvr2low »
i just had to be for my car and i got it from repco for 50 bucks thanks to mates rates haha so putting it in on fri
Re: Oxygen Sensor
Great post Bennoz, was just looking for one of these. All the info in one place! :thumleft:
