Power antenna switch?
indyfto
Post by indyfto »
Those of you that have a power antenna - the switch on the left side of the instrument binnacle (opposite the fog light switch) - is the switch pressed to lower and then pressed to raise the antenna or more similar to the fog light switch and stays pressed on or off and have like total control of the antenna aside from raising automatically when turning on the radio...?
Thanks.
FTO338
Post by FTO338 »
The switch is only 2 control the antenna lower or higher.
Assk
Post by Assk »
As FTO338 said!
The antenna has two settings:
LOW: In which case it sticks up about 30cm
HIGH: In which it goes all the way up.
Either way when you turn your car off the antenna still retracts all the way down.
indyfto
Post by indyfto »
Ok thanks for that guys.
