Moderators: IMC , Club Staff
JOeJOe
Posts: 1554 jedwabna poszewka promocja
Post
by JOeJOe » Wed Apr 11, 2007 11:19 am
I had a look on the NGK website, they have a universal 4 wire oxy sensor .. just wondering if it's ok to use on the FTO.
Also i've seen a post referring to an ACA brand, just wondering where I could get my hands on one.
Didn't want to start a new topic, can someone confirm whether the gates belt T987 can be used for GPX models.
Thanks
Joe
Posts: 23678 Joined: Fri Jan 21, 2005 6:00 pm
Post
by Bennoz » Wed Apr 11, 2007 11:35 am
Yeah that ACA one is the same across the board. There are also equivalents on Ebay that are even cheaper than the 88 odd bucks I paid.
http://cgi.ebay.com.au/OXYGEN-SENSOR-O2 ... dZViewItem
Gates T987 you can get from any Repco for about 95 bucks & it will fit a GPX. That part number (T987) is specific to the GPX
JOeJOe
Posts: 1554 Joined: Wed Mar 29, 2006 6:00 pm
Post
by JOeJOe » Wed Apr 11, 2007 2:05 pm
Got theOxy sensor for $80 bucks.
As for the timing belt, Repco wanted to charge me $220, then I told him I knew some guys who got it for $100, then he put down to $140. Told him I don't need it yet so I left.
Went to SuperCheap, lowest price is $152.
I'm calling AutoBarn.
JOeJOe
Post
by JOeJOe » Wed Apr 11, 2007 2:26 pm
Found something when I called Autobarn. They stock a Bosch Timing belt with the same part number for $60, not sure if its the same.
The guy asked whether the FTO use a square tooth or round tooth, I have no idea. HELP !!!!
Post
by Bennoz » Wed Apr 11, 2007 3:03 pm
Sqaure tooth
tadasu
Posts: 61 Joined: Mon Feb 05, 2007 6:00 pm
Post
by tadasu » Thu Apr 26, 2007 11:42 pm
where can i find info about changing oxygen sensor?
JOeJOe
Post
by JOeJOe » Mon May 07, 2007 10:58 am
I can't beleive how easy it was to change the oxy changer, I'll be doing it myself next time.
Unscrew
Cut cables
Join cables, and
Screw in back in.
I estimate about 30mins if you're doing it at home.
Post
by Bennoz » Mon May 07, 2007 11:02 am
Unless she's rusted in... then its a can of WD40 & some elbow grease...
But yeah, not a hard job.
JOeJOe
Post
by JOeJOe » Mon May 07, 2007 11:43 am
Mine was easy, wasn't rusted at all.
I've driven my car about 150k's already and i can see the difference in fuel consumption since that change. Usually at 150ks i'd use almost half a tank, atm it sitting on the 1/4 mark.
Should've changed it sooner, would've saved me a lot of money !!!!
