Engine start then die and also cut out while driving !!
kni8ht
Post by kni8ht »
damm it.. it happened again idle normally at 1,000 rpm.. driving along then 500 rpm, drive bit more .. wooo is about to die... 1min later gone :evil: <engine cut off> arrrrrrrrrrrgggg
Looks like a new one is needed, anyone got a part number.. or know a good place ot get a replacement stepper motor??
cb wrote:how do you clean the stepper motor? and solenoids on alternator?
micro fibre cloth and some elbow grease and WD40... not sure if this is the correct way of cleaning thou...but is cleans well.
izonme
Post by izonme »
Dont Know..........
Trying running your car again for 30min in Park. I don't think it would be broken.
I had this problem like a bitch to if it dropped under 1000rpm it would die. All I did was disconnect the battery both + and - leave it for 30min then run the car for 30min and then take it for a drive.
.:-- 1997 BLACK / GPvR-FTO / KENNY9 --:.
cb
Post by cb »
kni8ht wrote:micro fibre cloth and some elbow grease and WD40... not sure if this is the correct way of cleaning thou...but is cleans well.
Ah ok cool thanx, do you need to take it off and stuff? I need details on how to do that and which bits to clean etc!
kni8ht
Post by kni8ht »
I finally got a new Stepper motor from http://www.nardek.com.au/iscsub.htm The package I got show it's a Mitsubishi Genuine parts (510-16)
$195 later I finally fitted the new stepper motor and wala the issue is gone. I drove the car for few days now and it seems fine.
This is what Camskill had on their website about the installation/cleaning, which I followed:
1. Remove old stepper by undoing the electrical connector and unbolting from throttlebody fast idle valve.
2. Clean area where stepper plunger goes into throttle body.
3. Fit new stepper.
4. Start car and wind idle screw in until it idles properly at about 2000rpm cold.
4. Wait until normal temp is reached at 2000rpm now adjust idle back down to 850~900 rpm.
