handling issues
jonowong
handling issues
Post by jonowong »
lets say i was on the track, I'm used to doing this turn at about 80-90 kmph but this latest time I've attempted the turn at the same speed i oversteered wtf caused this?
You were punching it in too hard & when you realised that, you backed off then hit the gas again when you'd slowed a little. I like to call it snap back!
that was the second you looked at your speedo
Jono
Post by Jono »
u sure you were on a track?? :wink:
Jono
bigpitty1
Post by bigpitty1 »
having a stiffer sway bar in the rear than the front can give more of an over steer effect which the fto has, having the front sway bar stiffer gives you a more direct steering feel, or something along those line correct me if I'm wrong.
jonowong
Post by jonowong »
ive done no work to the back!
but i did do what ben said i did!
yes im sure i was on the track!
oodLes
Post by oodLes »
Wtf, degrading tyres? Or maybe you threw it in a bit hard and too much momentum. You're really pushing her if you're oversteering at 90, I've done that or more over roughly 45* bends that are on a rise and had nothing like oversteer.
Jono
Post by Jono »
which track, which turn?
Jono
mr-charisma
Post by mr-charisma »
What was the turn like?
