faulty engine temp gauge
oneian
Post by oneian »
hi all.. there's two after market "mitsubishi motors" gauges above the centre console.. the vaccum one works just fine, however the engine temp gauge just sits at zero :(
Only when i switch the engine off, the needle jumps up for a bit..almost sparking to life, but then, nothing.
any ideas/help please!!? am useless with electrics.. aaah.
Re: faulty engine temp gauge
oneian wrote:hi all.. there's two after market "mitsubishi motors" gauges above the centre console.. the vaccum one works just fine, however the engine temp gauge just sits at zero :(
Maybe the temp sensor is faulty ... Is it a sensor that is plugged in through the sump plug ... ???
oneian
Post by oneian »
aha, i have no idea but will try and check it out. I bought the car only a few weeks ago :) Thanks for the tip there..
The sender unit is a single wired plug that sits just below the coolant cap. Check the wire is connected properly there.
