Hi guys,
Has anyone come across the problem before where you ignitor/ignition failure sensor keeps blowing?
I have replaced 4 sensors now and something keeps causing them to blow (new sensors arent cheap!). It is at an auto electricians currently and they are trying to investigate the cause.
The sensor is part of the ignition system and tells the ecu to fire the coils.
Any advice is appreciated.
Thanks,
Mike
Ignitor/Ignition Failure Sensor keeps blowing
- onnzo
- onnzo
- bigpitty1
there are 2 capacitors one near the coils and one near the ignition failure sensor, I reacon they might of died, they absorb high voltages produced from the coils when the magnetic fields collaps, something on those lines anyway.
to test them get a digital multimeter, hook one lead to the wire and the other lead on the body of the capacitor, have the multimeter on ohms, the resistance should go from low to high then read OL, if it doesn't do this then its dead.
This one is for the coils located on the inlet manifold.
This one is located next to the ignition failure sensor, you said you have replaced you ignition failure sensor, make sure the capacitors are bolted to the engine so they are earthed.
- onnzo
Thanks Bigpitty,
I did notice the capacitor when replacing the sensor (but i didnt know what it was at the time). I did bolt it down when I replaced it (the one on the ifs) and noticed that it was grounded to that "metal plate with the thing on it" is what I called it
I will call the auto elec tomorrow and ask him to check it.
Has this happenned to you before?
Mike
Mike
- onnzo
cool - well thanks for the suggestion. You would think that auto elec would think of it- i have gien him the workshop manual and the electrical wiring diagrams too!
Mike
Edit- for reference, if anyone else has this problem - mine was casued by one of the wires to the sensors being grounded. Engine movement was casuing the loom to rub against the bracket holding the condensor resulting in a short.
It cost me $900 all up for an auto elec to trace the problem! $550 of that was labour, $130 for tow, $185 for sensor (this is more expensive then genuine at $140, but genuine was 4 weeks ex japan.) $50 for other misc stuff.
Mike
