Bennoz spends more money - NOS!
- AMACHA
- I8A4RE
- QLD Coordinator
How complicated is the system, is this something you would feel comfortaable installing yourself ben or definitly something a pro has to do?
Well... I might not have to pay $100 per refill
Thats retail rates.
Im actually running a Type A unichip & strangely enough, an aftermarket ECU does not have to be remapped. The guy who tuned it tried to explain how the tuning works but I didn't quite understand it. It has something to do with fuel pressure & the stock ECU. I'll try & find out more about it.
Still going blown but am doing that on another motor.
![Razz :P](./images/smilies/icon_razz.gif)
Look, in esscence you could probably install one yourself, all it is is a bunch of lines & connectors - but I wouldn't recommend it. If you f*ck it up, you could really damage (blow up) something or yourself. Also by law, the bottle mounting has to be welded to the car.I8AFRE wrote:How complicated is the system, is this something you would feel comfortaable installing yourself ben or definitly something a pro has to do?
- FtoSam
Yep. Blue is nos, red is fuel. The fuel line is branched off just after the FPR.FtoSam wrote:Wet... Thats with both NOS and Fuel being injected into the Intake right??Bennoz wrote: - standard internals. Is a wet shot.
Where abuots is your injection point???
And i want pics!!!
![Image](http://img159.imageshack.us/img159/3720/img3523in5.jpg)
That above pic is of the bottom of the intake pipe. It comes up underneather it just into the 90 degree bend near the throttle body. There are no pics to show cause you cant see anything! Thats the beauty of it!. The solenoids are mounted to the firewall just down near the fuel filter & line comes out of the chassis rail near the air con breather pipe & straight up into the solenoid then into the intake pipe. You see nothing... well at least your average cop would see anything!
![Image](http://img164.imageshack.us/img164/1571/dsc00501640x480ya4.jpg)
- FtoSam
- I8A4RE
- QLD Coordinator
That is WICKED, look how F&*ken steep it climbs. ![Shocked 8O](./images/smilies/icon_eek.gif)
- I8A4RE
- QLD Coordinator
im not surprised, she doubles KW's within 500rpm and gains 100nm of torque within 1000rpm, you so gotta take me for a spin
- aza013
- NSW Coordinator
