reverse light switch not connected
speedcrushdemon
Post by speedcrushdemon »
My reverse light is not working. I used to to think it's a faulty reverse light switch. But then when i tried to find it out, i realized that the switch is not connected to anything. And i couldnt find the cable/bracket that connects to it either. Has anyone faced this problem before?
Or should i hook a cable out from one of the cable in the engine bay? Im confused :?
Thanks.
<a href="http://s6.photobucket.com/albums/y217/jacobchan83/FTO/?action=view&current=15362_206082000019_607980019_447264.jpg" target="_blank"><img src="http://i6.photobucket.com/albums/y217/jacobchan83/FTO/15362_206082000019_607980019_447264.jpg" borde
nikhan
Post by nikhan »
Did you check the front of the car, my reverse light went out once because it was the problem with a sensor at the front. If im not wrong there should be wires together with the rear lights.
Yeah there's a 2 wire switch bolted into the front of the g/box that is switched when you go into reverse. I'll try & dig up a pic of what it looks like.
Check to see whether its connected. Failing that, MD730979 is the part number. About $45 from Mitsubishi - common to lancers & anything else with the F5M42 g/box, so you wont pay huge grey import part prices.
speedcrushdemon
i do have the reverse light switch sticking out from the gear box... but it's not connected to any wires... where could the wires be? where should i find them from?
Thanks
