amp keeps blowing fuse
- azza
hi all.. i was powering a 300W pioneer amp which i replaced today with a 400w amp, now when ever i connect the power the amp fuse is just blowing. No wires are touching and everything is connected properly. I replaced the fuse on the amp and i then connected the power again but this time at the battery end with the fuse.. and its still blowing.... is it possible that the fuse i have near the battery needs to be higher? (this fuse doesnt blow just the one on the amp its a 15a fuse) or any other suggestions to what it could be?
- RK1-WhiteKnight
- craigt
doesnt matter how many subs hes got at the moment as the way hes described whats happening is hes not even getting a chance to turn the head unit on.
this 400w amp you are using is it new or 2nd hand?
if its new take it back to where you got it and ask them to test it.
if its 2nd hand then theres a good chance it rooted anyway take it to a caraudio shop and get them to fire it up on their test bench. it may have a short to ground inside the amp somewere.
- craigt
- craigt
