ok so story ...
i have a manual GR, also have petes old auto GPX
converting my GR to mivec,
can i use his auto loom and jus not connect the extra clips?
already got the manual GPX ecu too
any help would be awsome
LOOMS auto and manual
- nathan
Re: LOOMS auto and manual
Almost. On the auto gearbox loom (large black plug) you will need to join the two bigger wires (black with yellow stripe and black with red stripe) together. This is to fool the ECU into thinking the car is not in gear & hence will start when the key is turned.nathan wrote:can i use his auto loom and jus not connect the extra clips?
You will also need to wire in the reverse sensor to the red with blue stripe and black with yellow stripe (small wires), these are positioned next to each other.
