couple of questions
scanley
couple of questions
Post by scanley »
1) What is the fuel tank capacity of the 1995 GPX?
2) Are the throttles normally so light your foot aches from holding it off (yeah yeah - laugh all you want!)
eddiii
Re: couple of questions
Post by eddiii »
1. from i remember its 60L?
2. not sure :)
1. Yes they are a 60L
2. Yes they are light.
Nope, 70lts :D
I had a drain plug installed, completely drained it and refilled it, with foam installed it took 68lts.
brad_gpx
Post by brad_gpx »
my clutch is the opposite its really heavy, my foot gets sore if i leave my foot on the clutch at light
brad_gpx wrote:my clutch is the opposite its really heavy, my foot gets sore if i leave my foot on the clutch at light
Then pull it out of gear. Leaving the clutch depressed for extended periods will cause premature wear of the thrust bearing - aka box out to replace.
^^^^^ :lol:
brad_gpx
Post by brad_gpx »
i do
im just saying that if i leave it in gear my foot gets sore :lol:
You ought try holding mine down. The left side of my entire body goes numb :lol:
brad_gpx
Post by brad_gpx »
i remember when i was first learning to drive and i'd only driven manual in my car
and then i drove the instructors car and i told him i thought his clutch was broken :facepalm2:
Shane001 wrote:Nope, 70lts :D
Car running on fumes juddering like sh*t and it only took less than 60 litres.
vipfto
Post by vipfto »
thats interesting actually as I have put just over 60l in before and wasnt out of fuel? is there a chance that some may of been fitted with say a different tank? like they used up some old tanks they had around before new ones were availible etc?
More likely doggy servos.
payaya wrote:More likely doggy servos.
is "doggy" your word of the day?
Servo's arent dodge the pumps actually calibrated to compensate for when the fuel shrinks, so your getting that little bit extra. Also I filled up my car 65L just after they calibrated the pumps and it had just reached the fuel light so still had that 3 litres or so left. So yes id say it has around a 70L tank up to the spout.
Good memory! Mines pretty doggy on the weekends usually.
BorepYano
Post by BorepYano »
if it's a 70L tank, then 5 or 10L is unusable...
I've actually ran out of fuel before (as in I had to call RACQ to come to me on the side of the rd), and when I filled it up after, I only managed to squeeze in just over 60L (including the 5L RACQ put it), have to admit I didn't fill it up till it spilled out. And once before I have sqeezed in 64L, but that did overflow.
just my 2 cents worth :)
