High pitch whining... Pwr steering pump?
- Ollie
Hey guys
jst wondering I have this high pitch whining noise in my engine bay. Now I feeling it my pwr steering pump, bt thers no leak or air getting to it. I flushed it and replace the fluid bt the sound is still ther. Does anyone Noe if this is the corse of the noise. because I don't wna buy a part that I don't need.
Oh snap! I'm the Asian Ollie...
- I8A4RE
- QLD Coordinator
Re: High pitch whining... Pwr steering pump?
Well very hard to diagnose without hearing the sound mate but it could be the pulley itself or one of your other pulley's or it could be just a loose or worn belt. To be honest it is not something that can be diagnosed over the net.
- Cassf88
does it happen during the colder mornings or its constant?
does it speed up when the car accelerates or is it a constant regardless?
does it ever stop, eg: if youve been driving for half an hour, an hour, etc?
you can never give too much info
- vipfto
most likely to be alt or pwrstr belt mate esp if high pitched like a squeelOllie wrote:Hey guys
- Ollie
Well yes when engine has not be started let's for for 4 hr it makes a sqeaking nosie. But the belt is tight, I have tried losing n tightening n still the sqeaking does nt stop until the car is warmed up.
Nw the whining nosie is constant and does nt disappear. when I do accelerate it does get louder. The fluid is at its max n has not come down.
- vipfto
shall be one of the belts then. (there are two and one tensioner on top one underneath)
can be either too loose, too tight or just stuffed for the sake of $30 per belt just replace them
I think itll be one of the idler pulleys. They squeal like bastards when the bearing in them starts to go.
- Cassf88
i believe it is your pulley because my car has the same issue and it was diagnosed that its my A/C pulley. With the way that it sits in the engine bay, its closer to the ground (or so i was told) and therefore that is the reason
get a new pulley if it irritates you too much
edit: poorly constructed sentences
- vipfto
as its only happening when car is cold my money is on belts, IMO replace them first as cheaper option if still makes noise then start with pullys
- I8A4RE
- QLD Coordinator
Hey has two issues squeeing and whinning
Squelling will be belt definitly
Whinning I would think would be the actual power steering unit itself.
Ok first, take off power steering belt and start car. Has that removed either noise, both or none?
- Ollie
I'll try that n see what happens. Bt I have a very gwd feeling itS the whole unit.I8A4RE wrote:Hey has two issues squeeing and whinning
- Ollie
Yeh guy I got my pri bar and had a listen defenitly pwer steer pump.
Also my tension roller is pretty banged up.
PS pump aint too bad to swap out. Very messy thou..
- Ollie
Ben would u have the assembly of the pump. Like wher to unbolt n stuff
Its pretty easy to unbolt. 3 bolts hold it on, but from memory you might have to remove the aircon compressor as well to get it out. There are 4 bolts on that. Easiest to remove from under the car IMO. The power steering fluid makes a mess though and unfortunately you have to unplug the pipes to swap the unit over.
- vipfto
dont need to unbolt a/c compressor
think its 3x bolts 1 from engine of it 2 from belt side whick you need to acces through pully holes
- Ollie
Thanx guys. Big help
- Ollie
Argggh I fixed the pump. Btw thanx dawyne!
Bt the tensioner and the compressor is noisy too. If anyone has these parts please pm me need them.
