air intake
bduffman
air intake
Post by bduffman »
hey guys just a question bout the intake
i own a gr and would like to upgrade it
i know the gr needs to keep the maf sensor so options get limited
wondering if any one knows of some after market designed for the gr
Re: air intake
You can use any of them as long as you add the maf to it.
Re: air intake
aza013 wrote:You can use any of them as long as you add the maf to it.
+1
vipfto
Re: air intake
Post by vipfto »
bduffman wrote:hey guys just a question bout the intake
have a look at my DIY
Re: air intake
2 x 90 degree silicone bends, a 3" MAF adaptor plate & Bob's your uncle. Keep the MAF as far away from the filter as possible.
Re: air intake
Woah bobs my uncle!?
Gholdwayne
Re: air intake
Post by Gholdwayne »
that was random :lol:
but funny... ah ben
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
bduffman
Re: air intake
Post by bduffman »
nice set up bennoz might do the same sorta set up altho a diff box cause my batterys to big
dose any one know if its better to have a small or large box
bduffman
Re: air intake
Post by bduffman »
what about the small air inlet to the engine what did you do about that should i just throw on a tiny filter or connect a pipe in after the maf sensor
dose the engine take in air from here or is it used for some thing else cause swear one time i left it off and it threw out the engine what should i do
cause i dont want to throw out fuel to air ratios
zuihoujueding
Re: air intake
Post by zuihoujueding »
i think the size of airbox does not matter too much.
what it matter the most are
1) pipings to have least bends
2) air filter with a good balance of flow and filtration
3) airbox sealed from hot air
4) insulate the pipe if its metal
