300cell,200cell,100cell cat ???
Rambo
Post by Rambo »
Just wondering what is the perfect cell cat for the fto?
lower the cells , louder it is right? does that mean more power?
, and what size do you have in your exhaust system and what brand?
I already had an exhaust sytem in the car when i bought it,
2.5inch piping and thinking off buy a 200cell may 100cell?
JDMstyletuning.com
Froto.gr
Re: 300cell,200cell,100cell cat ???
Post by Froto.gr »
Rambo wrote:Just wondering what is the perfect cell cat for the fto?
200cpsi hi-flow cat
2.5inch mandrel bent pipe
1 reonator
rear muffler of choice
you get more power
when get all fitted ill add more to for now it will do,
im odering back box it will be between mongoose/blueflame/hks they all have different tones so it hard choice,, :twisted:
Gholdwayne
Post by Gholdwayne »
200cpsi hi-flow cat
1 reonator
you get more power
^^^ Yehp, what he said. Except for the muffler since you are in Ireland. we cant buy mongoose/blueflame/hks locally around here, except maybe an hks or two that i've seen in import shops.
For a high flow cat, looking at loudness, it only increases the volume and rumble subtly, but if you put headers/extractors in, i think it will give the car's growl more body and depth.
As for performance, the catback by itself will only give minimal gains there. Adding a high flow cat, it will only give a small but enough to be noticeable gain, but only because it's full potential will not be utilized until the extractors are upgraded as the stock one's downpipe is very restrictive.
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
BorepYano
Post by BorepYano »
I'm actually pretty interested in why 200cell not 100cell?
0 cell for the win :twisted: (for track use only)
im running extractors, hiflo cat, 2 resonators all in 2.5", after over axle it turns to 3" and into a 3" inch muffler and tip. havent heard anyones fto with the same note. ill post vid up later
its a 200cell as well
Gholdwayne
yeah 200cell is the one that usually complies
97 GPX Icelle Blue
FTO[For The Orgasm]
yeah screw goin illegal on a cat, if epa guys get you your fucked.
Meh
Bennoz wrote:Meh
Thats a huge risk.
Kustom_FTO wrote:
Bennoz wrote:Meh
Thats a huge risk.
They degrade over time anyway! And guess what they do as they degrade? They crumble & blow out the exhaust.
Its not an 'instant' fine, you'll just get told to put a new one in. They only way you get hit with the big bucks
is if they can prove you've deliberately punched it out - aka have a shiney new one in there thats clearly empty...
Gholdwayne
But not to worry, cats take aaages to degrade. I know mine was replaced on import back in '06 or '07 i think, still a stock replacement, and the honeycomb was still very much intact when I had a look at it after replacing with a high flow 200cell one. Could not see daylight too well through the stock one.
97 GPX Icelle Blue
FTO[For The Orgasm]
Kustom_FTO wrote:
Bennoz wrote:Meh
Thats a huge risk.
Oh okay, I thought you ment you had a decat pipe on there, not a punched cat :lol:
