Rear control arms
Rear control arms
I am currently looking for rear upper and lower control arms and possibly front camber adjustable pillow tops
Re: Rear control arms
theres some on ebay actually a whole fto rear end i believe
Whats wrong with your old control arms?
- Storm
Give them a good check over. I replaced most of my rear suspension only to find the upper arms were good and the lower ones were fubarred. Upper ones dont seem to wear at the same rate.
I didn't buy lower ones so have to do that bit still
Yeah, that & you can press out the bushes. Good as new!
What bushes are there in the rear end? LOL
lol serious, ive still got knocking after the rear swaybar chassis and droplinks have been replaced.
Do u have the codes? and how much approx for them
Head over to the suspension thread mate, it's all there.
but i get lost in it and mines a gpx not a gr, does it matter?
Only difference between GPX & GR rear ends is in the droplinks... but if you'd read the f**ken suspension thread you'd already know that!
okay had a look at the suspension thread, theres 2 control arms on both sides that could be knocking am i correct?
Is there a bush on either end of the control arms?
- Storm
There are two control arms and a swinging arm, all with bushes of different types at the ends.silverGPX wrote:okay had a look at the suspension thread, theres 2 control arms on both sides that could be knocking am i correct?
Have a look at the outer bush in the actual swinging arm, it'll be fooked first.
so confused lol. ill have a look tommorow
As far as i can tell there is a bent/knackered control arm somewhere in the mix but i thought i would do the lot as preventative, at the moment just finding out what options i have
- Storm
Upper dog bone - least likely to be causing the knocking IMO - http://www.camskill.co.uk/products.php?plid=m3b0s10p838
Lower dog bone - likely to be fooked - http://www.camskill.co.uk/products.php?plid=m3b0s10p840
Swinging arm, outer bush likely to be fooked - http://www.camskill.co.uk/products.php? ... b0s10p7626
Bush for above arm - http://www.camskill.co.uk/products.php? ... b0s10p1075
Replacing the bush on its own seems like a good idea but often the inner bush is stuck so getting the arm off to press out the outer bush can f**k up other parts. I would be inclined to either get another arm to refurb or just get a new arm.
Bill
Bill
I'd start with this one. Its the most common to go.Storm wrote:Bush for above arm - http://www.camskill.co.uk/products.php? ... b0s10p1075
