Clutch Bleed
Clutch Bleed
How do you do it?
thanks in advance :)
Re: Clutch Bleed
Generally just stick it in & thrust, wbu?
bduffman
Re: Clutch Bleed
Post by bduffman »
Were not talking bout 13year old virgins here kustom lol
Just to add to this question mine has a leak or some thing where would it leak from
Re: Clutch Bleed
You bleed from the slave cylinder which is located on the gearbox, just behind the radiator hoses.
Has a bleed nipple (yes I said nipple) that you open & bleed with just like you would do the brakes. Ie take lid off master cylinder, fill with fluid, pump pedal & then hold down, release bleed nipple, tighten bleed nipple, release clutch pedal - repeat - adding more fluid to the master cylinder as required.
Its usually the slave that goes, but I you really ought replace both master & slave at the same time. When mine went, I replaced the slave, then 20kms later the master blew :|
Re: Clutch Bleed
can i use DOT 4 brake fluid in it?
Re: Clutch Bleed
Yep
