Limp mode
FTO-BOY
Re: Limp mode
Post by FTO-BOY »
I thought in the manual it says that if it's flashing at 1hz then it's could be one ofthe sensors?
Re: Limp mode
Nope that means no errors.
See here.
http://ftoaustralia.com/v3/viewtopic.ph ... c9ddfb63fb
FTO-BOY
Re: Limp mode
Post by FTO-BOY »
With a flashing N lamp there are two possibilities of what it could be.
If it flashes at 1Hz, once a second, then it will be either,
Input speed sensor
Output speed sensor
Solenoid valve
Out of phase at shift points
A/T control relay system
If it flashes at 2Hz, twice per second, the ATF temperature is too high and you should stop to allow it to cool down.
Storm
Re: Limp mode
Post by Storm »
The above applies only when you are NOT activly looking for codes if I remember correctly.
That is, car has slipped into limp mode and is flashing all on its own.
Re: Limp mode
Storm wrote:The above applies only when you are NOT activly looking for codes if I remember correctly.
Spot on... FREE COOKIE!
Storm
Re: Limp mode
Post by Storm »
Woo-Hoo. Free cookies!!!!
FTO-BOY
Re: Limp mode
Post by FTO-BOY »
Nope.. its not the sensors guys..
Again started it up and put it in drive and it just revs and very very slowly moves forward (actually i dont know if moves coz of the gear box or because of the slight angle on my driveway)
Is it safe to assume that the gearbox has had it?
Re: Limp mode
I thought 2HZ so two flashes a second meant no codes when in diagnosis mode? 2HZ during a drive is overheating??
Re: Limp mode
FTO-BOY wrote:Nope.. its not the sensors guys..
What colour is the oil?? Is it at the right level? Seems like your torque converter has had it.
FTO-BOY
Re: Limp mode
Post by FTO-BOY »
Yeah did an oil change for it last week when it stuffed up.. yeah i think is the torque converter too. Even on a bad oil the gearbox should still get to firs gear. correct?
Re: Limp mode
Well if your oil was not red when you changed it, I can only imagine your torque converter rippings itself to shreds causing your oil to burn. Take a sniff of your oil and see if the oil smells burnt.
My last rebuild cause no drive. It was like I was in neutral and could not get any drive at all. Transmission guy showed me my torque converter and it was not a good sight.
FTO-BOY
Re: Limp mode
Post by FTO-BOY »
yeah oil was very dark. how much did your rebuilt cost?
Re: Limp mode
Too much!!
