changing clutch
bduffman
changing clutch
Post by bduffman »
hey guys i plan on getting my clutch changed and was wondering should i get the EXEDY HEAVY DUTY CLUTCH MBK-7277HD
seeings im having the clutched changed is it worth getting a lightened flywheel and if so how much RPW sell them for 363.64 , ive herd there prob not as streetable as stock has any one used one befor in there fto
thanks
arrrr stupid front bar im gona have issues again with getting work done to the car :(
bduffman
Re: changing clutch
Post by bduffman »
ok its booked in was like $500 or so for install
clutch is $450
cvs will be about $100 or less
plus ill prob pick up cold air intake while im out
vipfto
Re: changing clutch
Post by vipfto »
+1 to lightened flywheel (well worth it)
either get ripped off at RPW or can definatly buy cheaper elsewhere or just get yours milled down ;)
MH999
Re: changing clutch
Post by MH999 »
bduffman wrote:ok its booked in was like $500 or so for install
clutch is $450
Does the clutch come with a thrust bearing aswell?
If not then you should get that changed too,or else you will get a nasty
grinding noise at low rpm.WTF $500 just for install thats cheap.
bduffman
Re: changing clutch
Post by bduffman »
yea $500 cash job install but that didnt include the cvs but my mechanic called back ( the one i had do all my engine work ) and told him ive booked it in what i was getting done and he told me leave it with him, hour later called back said he will do it all for $1290, that included buying the clutch having the cvs sent off and rebuilt both inner cv and outa cv plus install clutch and cvs
clutch would have been $450 cost price
he said cvs rebuilt were $180 each ( slightly more then that other company that sell the swap units for 150 but they dont sell the inner one so dont know how rebuilt they are )
so hes installing it all for $480 only prob is he needs the car a few days so the cvs can be sent off to be rebuilt but thats alright
bduffman
Re: changing clutch
Post by bduffman »
ok so ive looked at the rpw site and there lightened flywheel says Mitsubishi FTO 6A12 DOHC incl Mivec - 5.2kg / 7 Bolt Pattern
but the brands Fidanza flywheels i went to there website http://www.fidanza.com/aluminum-flywheels.aspx and there specs say its for Galant 92-94 2.0L NT 7-bolt Crank (part number) 161971 Alum. Weight 8
