Overheating
redgoesfaster
Overheating
Post by redgoesfaster »
Hey Guys,
I got an FTO as a part payment back in Nov/Dec. When I first went and looked at the car we found an issue where the thermo fans were running continuously therefore the temp was sky rocketing when idling and under heavy accelaration, there was also no water running through the bottom radiator hose it was cold. So the guy I got it off replaced the temp sensors, problem solved worked ace. Up until now. Last two days, I travel about 45kms down the hwy to work, when I'm going down the hwy at 100kmh it sits on its regualr temperature. I get into traffic on my off-ramp and it goes up to about 3/4 and sits there. I get off the off-ramp onto the road and drive again and it goes back down to normal? It's been doing it the last couple of days. I sat it outside on idle when I got home from work today for about 8 mins or so it went a bit over 3/4.
I'e checked fluids and is all OK, water is running through both hoses. Any ideas on what I could check or what the problem is? I'd assume if it was the head it would be using water?
bduffman
Re: Overheating
Post by bduffman »
If its the head there will be white milky stuff where you pour the oil in
Replace therostat flush coolant put in some good coolant and see if that fixes it ( did with mine )
Re: Overheating
If there's milky stuff under the oil cap, you have water mixing with the oil. Aka - a blown head gasket.
Re: Overheating
Check that both fans are still turning on. Sounds like one of them isn't.
redgoesfaster
Re: Overheating
Yeah both of the fans are running. Checked the oil this morning, no milky substance and it's not chewing any water.
Thermo sensors were replaced 2 months ago with a fresh coolant flush. Should I do it again to see if it changes anything?
Top radiator pipe is a bit swalloen, but still runs water through it fine.
Re: Overheating
Maybe water pump?
    bduffman
    Re: Overheating
    Post by bduffman »
    It will be a bitch if its your water pump as its part of your timing belt
    For the sake of under $100 ild replace the therostat and flush it and put good coolant in
    Mayb while your at it flush the radiator to could be a blockage in that
    If none of that works then you will be looking at a bit more money to get it fixed
    redgoesfaster
    Re: Overheating
    Pulled it to bits last night. Thermostat was stuck. So fixed that. Still to no avail. To find the radiator blocked. So it will need a flush, depending on the severity maybe a new one. But I'm glad its not the head...
    Re: Overheating
    Try a reverse flush mate and see what happens.
    Re: Overheating
    Mate same thing happened to mine. I just pulled the radiator out and flushed the sh*t out of it. and then new thermostat and some good coolant and it sits just below a 1/3 and never moves ever lol
    redgoesfaster
    Re: Overheating
    Yeah mine sits between a third and halfway, more leaning towards halfway generally.
    Re: Overheating
    Yeah mine used to creep up to halfway and then further if i didnt stop only at highway speeds though. Thought it was a blown headgasket but just turned out to be a bit of crud in the radiator.
    Will probably need to be professionally flushed at some point, but until the situation arises again im not worrying.
