Hey guys, i went for an alignment and the guy showed me the problem.. he was wiggling the bolt on the driver side which was fine and i could literally see the camber changing but on the passenger side, guy said there wasnt any meat left on the bolt to move that plate/washer like thing...
Also, are these obtainable from any autostore? Maybe a lancer equivalent?
B>bolts - for rear camber/toe adjustment
- Gholdwayne
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- Shane001
Re: B>bolts - for rear camber/toe adjustment
They're a massive pita
You can get the washers & bolts from camskill, probably your best/cheapest option, or put a set of the Megan Racing arms on the back like I'm putting on the racecar (refer suspension thread), but I haven't tested these yet.
dstocks. Had to replace a set myself.
- bduffman
Any tips on replacing the part it mounts to ( bracket spot welded to chassis ) mines bent past repair mechanic said if he bends it back it will prob snap
Grind it off. Get some sheet steel & fold up a new one. Weld on.bduffman wrote:Any tips on replacing the part it mounts to ( bracket spot welded to chassis ) mines bent past repair mechanic said if he bends it back it will prob snap
Its only way you should be doing it, being a critical suspension mount & all.
- Gholdwayne
Bump?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Gholdwayne
I got a pair from a wreckers off a ce lancer vrx... looked like they were clean replacements... should be a direct replacement... will see what happens..
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
