Noob q about MIVEC controller
FTOgpx96
Post by FTOgpx96 »
ive heard about these mivec controllers, ive googled searched them and cant get a definitive answer to what one is and what it does or the application they are best used for so can someone who has had or got one please fill me in on this informantion, bit sick of talking to knobs who probably have no idea about them
Stranger : Nice Porche
Me : its not a Porche
Stranger : ah ok what is it a supra?
Me : nope
Stranger : what is it?
Me : its a mitsubishi
Stranger : Bullshit
Me : Check the badge on the front bumper :)
Re: Noob q about MIVEC controller
2 main points for the are..
1) they take out 180 k/hr speed limit
2) u adjust the mivec point. So you could make it kick in earlier.
There is much debate about adjusting the mivec point. U could probably find a few threads searching, but yeah Aza and I both have the same unit. He has got some good results with his car in general, so I have mirrored his set up.. Which I think was mivec cutting in 500rpm sooner..
A friend of mine use to play with his controller all the time.. But had no idea what he was doing. As a result, his car put out 89kw @ the wheels.. While a pretty much stock tip should any around the 100 mark..
FTOgpx96
Post by FTOgpx96 »
any advantage to having one with a CAI, 210cc injectors and sports exhaust?
Me : nope
Stranger : Bullshit
Some say they work and others say they don't :?
I have my one set to 5900rpm 400rpm above the factory mivec point as it smoothed out the air fuel mix. Factory setting (5500rpm) makes it run rich at change over, in turn you loss power but it sounds good :D
For what you are looking at you would be better off getting a haltech piggy back ecu and tune it to your specs.
This will give you a better power result.
This will also cut the speed limiter at the same time :twisted:
I hope that helps.
Valandis91
Post by Valandis91 »
just cut the wire in the ecu to delimit if your getting it for that reason.
ive got a mivec controller by dcuatro but i have no idea how to wire it in.
i need it for my cams as i need to change the mivec point. anyone have any idea?
FTOgpx96
Post by FTOgpx96 »
aza013 wrote:Some say they work and others say they don't :?
I hope that helps.
cheers :) will definatly look into that :) love that mivec kick back its way too addictive :)
Me : nope
Stranger : Bullshit
