replacoing old waterpump in service?
- fto617
hey guys since fto is getting old itt needs to have waterpump replaced.
In UAS major service thing in the website
they said u need to pay extra 550AU + labor to replace a waterpump
does it actually cost this much????
is it a big hassle to remove the waterpump?
- dannyboyau
- smorison
- The Godfather
- RallyMad
Guys the water pump they are talking about here actually pumps water and coolant around your motor and the radiator. But come to think of it I don't know what pumps the water up to the windsheild squirters, I thought that maybe there was just a little pump in the bottle of washer fluid themselves. I wouldn't think that much pressure would be required for that.RT wrote:I have concern on that too....G1 wrote:is that water pump for the windshield spray?
i think mine got a bit weak recently
What is it and what is it used for?
- smorison
- The Godfather
RallyMad wrote: Guys the water pump they are talking about here actually pumps water and coolant around your motor and the radiator. But come to think of it I don't know what pumps the water up to the windsheild squirters, I thought that maybe there was just a little pump in the bottle of washer fluid themselves. I wouldn't think that much pressure would be required for that.
the waterpump for your washers is located on the underside of the washer bottle... if they are going they should be easy enough to replace... i doubt they are unique to the FTO...
A lot of the time it is actually the nozzles that are blocked and it isn't the pump in the bottle.RallyMad wrote: Guys the water pump they are talking about here actually pumps water and coolant around your motor and the radiator. But come to think of it I don't know what pumps the water up to the windsheild squirters, I thought that maybe there was just a little pump in the bottle of washer fluid themselves. I wouldn't think that much pressure would be required for that.
- RallyMad
Ahh yes, the old faithful needlesalacious wrote:A lot of the time it is actually the nozzles that are blocked and it isn't the pump in the bottle.RallyMad wrote: Guys the water pump they are talking about here actually pumps water and coolant around your motor and the radiator. But come to think of it I don't know what pumps the water up to the windsheild squirters, I thought that maybe there was just a little pump in the bottle of washer fluid themselves. I wouldn't think that much pressure would be required for that.
