whistle sound in my engine
- andie066
i dont know what it is but i keep hearing it for a while when i first turn the car on. and also when i drive it too hard... what is that sound and is that bad? and also today i turned my car on after not touching it all day the car missed the first rev... (that rev u hear when u turn the car on)....
i donno what to do... maybee service it? oil cahange or something... can anyone help?
- FTO338
- debbie
hey
hi, there are two belts on the right hand side, you can see them easily. one is small and the other is larger. i think they are fan belts, not exactly sure what they are called but my car has the same problem. whoever had the car before me had the wrong belts put on. the ones on my car only have 4 notches, where our cars need one with five. you can feel under the belt to c how many notches are there. when i get my car serviced next, they will change them for me, will cost me about 15 dollars.
goodluck:)_
goodluck:)_
- smorison
- The Godfather
- FTO338
The only other whisle noise i know its when the alternator its about to go. And u can hear it during start up & under lots of load.
- Black_FTOGPX
It sounds like thats exactly what it is. When My air con compressor (which also controls the Power Steering) caught on fire, I was getting the same noise before it went. I suggest you get it checked out ASAP before it catches on fire like mine did!!Black_FTOGPX wrote:Power steering can make a whistling noise if your belts are loose and slipping
- smorison
- The Godfather
debbie, you could buy some belt grip spray to cure the squealing problem. ive used it on other cars and it works a treat. if your current belt is still in good condition then it would probably be a good idea to get some instead of replacing the belt. the spray is available from most auto parts stores.
