Washing Engine
Washing Engine
Hi guys,
Is it ok/safe to degrease and high pressure wash the FTO motor?
Especially with the MIVEC plastic cover off.
If not, what should I be covering?
Thanks
Re: Washing Engine
I would always cover altenator and anything electrical ...
On old cars that would include distributors.. In newer cars, it is the spark plug/coil set up, as each spark plug maps to a coil pack ...
I haven't looked under the cover to see if it would cause any damage though ...
Gholdwayne
Re: Washing Engine
Post by Gholdwayne »
I've washed and degreased my engine a couple of times...
The only thing I really avoided getting wet was the pod filter... Maybe from today on, i'll avoid the alternator too...
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
nazGPX
Re: Washing Engine
Post by nazGPX »
i've done this, turn up to be the water to enter the spark plug hole n got misfire.. the car vibrates like sh*t.. just use the compressor to dry the engine and inside the spark plug hole.. cheers
Re: Washing Engine
I've done it, I just bag the pod.
Re: Washing Engine
^ same. And after your done go for a drive for 10minutes to heat the engine up and evaporate most of the water.
Re: Washing Engine
Go for a drive before as well, softens up any grease.
Re: Washing Engine
Just use brake cleaner!
Re: Washing Engine
payaya wrote:Just use brake cleaner!
+1 - a hoist and a spray bottle of brake cleaner is your best friend, takes 10min tops :lol:
