RH Drive Shaft
Private Sales Only
Fordman
RH Drive Shaft
Post by Fordman »
After a 25 spline drive shaft, RH (drivers side) To suit FTO Manual with LSD.
Located South of Sydney but will travel to pick up.
Fordman
Re: RH Drive Shaft
Post by Fordman »
Bump still need one...
Re: RH Drive Shaft
I think you will find it will be a mission to find one to mate with an LSD, i have a regular GPX shaft but not a GPR (i assume?) one - sorry
I assume you've already tried Dwayne? If he doesn't have you he might be able to source one for you
GL :D
Fordman
Re: RH Drive Shaft
Post by Fordman »
Not wrong about having trouble finding one. Have tried modifying one although the circlip wont seem to lock into the box and keeps sliding out of the box, only enough to come off the seal and leak all the oil out...
Re: RH Drive Shaft
Have you tried a cv joint shop? I'm sure they'd be able to do you a new one or replacement for a couple hundred.
Re: RH Drive Shaft
Yeah my driveshaft guy (Sydney Driveshafts) has found / made up / matched up bits for me..
Fordman
Re: RH Drive Shaft
Post by Fordman »
Found a drive shaft place in Auburn. He was bloody good. Shaft he sold me ($100 brand new) was almost perfect. Just the groove for the cir-clip was about 8mm too close to the end of the shaft. This i found out later.
I had a mate machine another groove in what i hoped was the right spot. Still no good!
Looks like i need to put a spacer behind the hub and move the whole shaft over 10mm.
Seems the gearbox ate the last cir-clip too 8O This bloody car is going to give me a mental breakdown GRRR!!
Fordman
Re: RH Drive Shaft
Post by Fordman »
But i gotta say the few little test drives have been.....fun 8)
