4spd LSD tip
4spd LSD tip
F4A42-1-W7A5 (LSD) MD974350
Or
F4A42-1-W7A2 (LSD) MD974108
Or
Re: 4spd LSD tip
Get the LSD out of the one in the UK sent to you. He was having trouble getting a drive shaft to fit, but is exactly what you are looking for. He is unlikely to move it easily, so you should be able to pick it up at a good enough price to offset the postage.
Re: 4spd LSD tip
EFAdstocks wrote:Get the LSD out of the one in the Netherlands sent to you. He was having trouble getting a drive shaft to fit, but is exactly what you are looking for. He is unlikely to move it easily, so you should be able to pick it up at a good enough price to offset the postage.
Re: 4spd LSD tip
Close Enough
Re: 4spd LSD tip
Reallydstocks wrote:Get the LSD out of the one in the UK sent to you. He was having trouble getting a drive shaft to fit, but is exactly what you are looking for. He is unlikely to move it easily, so you should be able to pick it up at a good enough price to offset the postage.
Which ones that?
Re: 4spd LSD tip
viewtopic.php?f=21&t=27648
He's now grabbing a standard tip, so can potentially part out the LSD.......
Anyway, look at the thread for more info!
Re: 4spd LSD tip
well saturday is the day... 4 hour drive - ferry - 2 hour drive to Cambridge.. to pickup a another autobox, this time WITH inner cv's
as soon as i have the other box out i will split it and sell the LSD. shipping should't be bad.. We also have an office in Sydney (PRA International) so i could ship with some computer hardware.
Re: 4spd LSD tip
Why don't u just convert it to manual
Re: 4spd LSD tip
manual licence?
Re: 4spd LSD tip
Wouldn't no where to start, I thought u can pretty much bolt an LSD on without to much work involved. Making it a cheap effective upgrade. For an auto..silverGPX wrote:Why don't u just convert it to manual
On my greens Dwayne so it doesn't matter, and didn't bother me when I was searching for a car.. If I could go back, I would be more patient and wait for the right fto to go up.
Re: 4spd LSD tip
destinationtoby wrote:Wouldn't no where to start, I thought u can pretty much bolt an LSD on without to much work involved. Making it a cheap effective upgrade. For an auto..silverGPX wrote:Why don't u just convert it to manual
Re: 4spd LSD tip
Yeah I won't be going near any of it myself, I ment cost wise. It would have to be a lot more expensive to pay a mechanic to convert it to manual then what it would to fit in an LSD ..I don't no much, so I may be wrong?Vectose wrote:Gearbox has to come out and be cracked open to install a LSD, and it isn't as easy as you think.
Re: 4spd LSD tip
You'd be surprised, taking the box out whether it be an auto or manual is where most of the time is taken up. Converting to manual isn't all that hard, I've done a couple now & the last one took me about 3 days - so multiply that by your Joe Blow mechanics hourly rate of 80-100 an hour, based on an 8 hour day, worst case scenario, that's only $2400 if you supply the parts.destinationtoby wrote:Yeah I won't be going near any of it myself, I ment cost wise. It would have to be a lot more expensive to pay a mechanic to convert it to manual then what it would to fit in an LSD ..I don't no much, so I may be wrong?Vectose wrote:Gearbox has to come out and be cracked open to install a LSD, and it isn't as easy as you think.
There's even a DIY guide on it that you can supply to a mechanic to save him time.
