Rocker cover gasket
Re: Rocker cover gasket
Sahin wrote:You don't own import, import owns you
In mother Russia, import owns all.
dstocks wrote:
Complete gasket kit should come with two rocker cover gaskets.
Nup, you have to order them separately.
what? since when?
(engine rebuild in 05 had them with)
Yeah, complete gasket kit includes both rocker cover gaskets.
Sorry, misunderstood. When I order MD309002 it is only a single gasket. You have to order 2 to get front and back. Wasnt referring to complete kit as that is not what he is after.
    Oh right my bad! :lol:
    Okay, so in looking to replace the gaskets, and plug seals soon.
    I looked up Camskill, I have a contact, so could perhaps get slightly cheaper shipping (depends)
    The set of 3 plug seals are
    http://www.camskill.co.uk/products.php?show=64228
    37.15gbp
    The gasket is
    http://www.camskill.co.uk/products.php?show=85232
    14.95gbp
    However, if I have non Mivec
    http://www.camskill.co.uk/m3b0s9p59/MIT ... _Non_Mivec
    19.99gbp WITH the plug seals.
    WTF...
    I have spent a fair bit of time searching, and cannot find the plug seals for Mivec to be any cheaper, or with a gasket kit, and they want 37.15 just for the plug seals???
    EDIT: Meanwhile, in Japan Land
    http://mitsubishi.epc-data.com/fto/de3a ... -head/746/
    Astron_Boy wrote: I have spent a fair bit of time searching, and cannot find the plug seals with a gasket kit.
    http://www.camskill.co.uk/m3b0s9p5811/_ ... V6_Engines
    I meant in comparison to the non mivec kit with the 3 plug seals and rocker gasket.
    Astron_Boy wrote:I meant in comparison to the non mivec kit with the 3 plug seals and rocker gasket.
    Oh, sorry, was just trying to help :D
    All good.
    Ended up going Amayama, cheaper in the end.
    Those plug seals are a joke on camskill.
    I believe payaya was saying that the plug seals were the same as a Magna and were only a couple bucks each from Mitsubishi Austalia.
    Same as 6g74 by the research.
    In the end, I need the rocker cover gasket, and not removing the cover twice, so...
