Moderators: IMC , Club Staff
fto96
Posts: 17 jedwabna poszewka promocja
Post
by fto96 » Fri Feb 07, 2014 11:03 pm
hey guys just got a few qeustions im installing a haltech inteceptor on my gpx my engine mods are , I/H/E i also want to get a bigger throttle body i heard that magna 3.5 ones are bigger and fit straight on all i have to do is port the manifold to match it right? any other engine mods i can do for it without cracking the motor apart
anyone else running a haltech on there n/a fto? and anyone got base maps? YES I SEARCHED LOL
Posts: 9529 Joined: Fri Jun 24, 2005 5:00 pm
Post
by dstocks » Fri Feb 07, 2014 11:10 pm
Aza and I have Haltech Premium piggybacks installed.
fto96
Posts: 17 Joined: Fri Feb 07, 2014 10:58 pm
Post
by fto96 » Fri Feb 07, 2014 11:12 pm
how do you like it? this is my first haltech on my personal car but i work with standalones at work but never tried out a piggyback one
Posts: 2703 Joined: Thu Oct 27, 2011 4:48 pm
Post
by shadowarrior » Sat Feb 08, 2014 12:22 am
Where did you grab yours from and how much did you pay fto96?
Post
by dstocks » Sat Feb 08, 2014 7:55 am
Love mine. Getting 133KW atw with significantly better fuel economy that I was getting pre-install. Once of the best value mods ivehad done.
Posts: 23678 Joined: Fri Jan 21, 2005 6:00 pm
Post
by Bennoz » Sat Feb 08, 2014 8:11 am
shadowarrior wrote: Where did you grab yours from and how much did you pay fto96?
Just come to terms with it, Tightwad
You need to spend at least a grand.
fto96
Post
by fto96 » Sat Feb 08, 2014 8:29 am
Yes its not cheap but you get what you pay for... i got it through my job, anyways bavk on subject 133kw sounds good too me
but can anyone comfirm that a magna tb is actually larger and will fit? And where i can find base maps
Posts: 7957 Joined: Thu Jan 12, 2012 12:25 pm
Post
by Daniel2019 » Sat Feb 08, 2014 8:56 am
Yes Magna 65mm throttle body will fit. Although be warned you will most likely run a bit lean on idle. At higher RPM you will be OK though.
Solution: keep it redlined!
Bennoz wrote: I got Bali beli & sharted on my phone. But it was fun
bjk wrote: you old people are no help at all.
Post
by dstocks » Sat Feb 08, 2014 9:10 am
Pretty sure ive got the base maps. PM me an email address.
Posts: 6793 Joined: Tue Oct 13, 2009 5:00 pm
Post
by silverGPX » Sat Feb 08, 2014 10:56 am
Lol its gem off facebook
Post
by shadowarrior » Sat Feb 08, 2014 7:13 pm
Bennoz wrote: shadowarrior wrote: Where did you grab yours from and how much did you pay fto96?
fto96
Post
by fto96 » Sun Feb 09, 2014 1:03 am
silverGPX wrote: Lol its gem off facebook
lol i made an account on fto australia right?? and cheers fella's and by running lean topend im geussing injectors run out?
fto96
Post
by fto96 » Sun Feb 09, 2014 1:06 am
Daniel2019 wrote: Yes Magna 65mm throttle body will fit. Although be warned you will most likely run a bit lean on idle. At higher RPM you will be OK though.
sorry bud didnt read that correctly i thought you said run lean at redline aha... cant i just add more fuel at idle with the haltech?( never tuned a piggy back before i know i can do it with a stand alone)
vipfto
Posts: 4154 Joined: Mon Oct 29, 2007 5:00 pm
Post
by vipfto » Mon Feb 10, 2014 2:57 pm
Sure can any reasonable piggyback can add/remove fuel at any rev range
