lsd swap?
lsd swap?
hi guys quick qeustion if i buy a lsd manual box is it possible to pull apart my box and the lsd box and rip out the lsd and put it in mine?
why you make ask only beacause i know my box is a1 and been rebuilt
- FTOwnage
Re: lsd swap?
You would need the drive shafts that came with the LSD donor box perhaps other things (someone correct me)?
Re: lsd swap?
hmmmm anyone can add to this?FTOwnage wrote:You would need the drive shafts that came with the LSD donor box perhaps other things (someone correct me)?
Re: lsd swap?
It can be done but yeah as said you need the shafts and just check with bennoz to be sure
- ZFL45H1
Re: lsd swap?
U only need to change the drive shafts if there is a difference in splines ie 25-27 (the two different diameters) others wise of the same that will work
Re: lsd swap?
Both manual boxes? Have a read here: viewtopic.php?f=10&t=24245#p283391
Re: lsd swap?
so that means i will need to change my hubs aswell? to a 27 spline?, actaully ill just change the spline on the hub end on the driveshaft with my standerd one and leave the box side 27
Re: lsd swap?
The hub side is all the same on every fto I'm pretty sure...
Re: lsd swap?
Isn't the ABS one slightly different?Sahin wrote:The hub side is all the same on every fto I'm pretty sure...
Re: lsd swap?
that's on the hub, but the shaft that goes into it is the sameTechnikhaus wrote:Isn't the ABS one slightly different?Sahin wrote:The hub side is all the same on every fto I'm pretty sure...
Re: lsd swap?
Ahh yeah, true. I was just thinking the hub itself..
Re: lsd swap?
Actually no there is a ring on the cv cup lol but if you had abs you'd just do that.. Lol
Re: lsd swap?
I'd love to do this swap, so I'd need the LSD, the gearbox that had the LSD fitted, and new drive shafts that fit?
I take it you can't just put the LSD in my current gearbox?
Re: lsd swap?
Yeah you can lol that's what th OP is asking! And what we've been explaining lol
Re: lsd swap?
Ahh ok, I get you now. I was reading as you would require the whole box. All good
- SchumieFan
- Supplanter
Re: lsd swap?
But then it wouldn't be a COTY anymore.SchumieFan wrote:Swap cash for lsd
